Configuring independent devices in DAQ Assistant
I am wondering why I can't configure independent devices in DAQ.   For example, in the DAQ assistant I can't call out a AI from a PXI 6259 in slot 2 of my chassis, AND a temperature reading from SCXI slot 1?   I have older programs (LabVIEW 😎 where I have done this before.  It seems as if now I need a separate DAQ assistant for EVERY card in the chassis?  That does not make sense.
Thanks for any help.
(2,326 Views)
Hi Jmc,
I don't think it's possible to do this with SCXI. Your DAQ card is using it's AI to read from the chassis, but you can use other functions like DI/O or counters. In these previous programs you mentioned, what hardware were you using?
Also, what kind of readings are you doing with the 6259 and what card is the SCXI?
Josh Y.
(2,314 Views)
