Changing 3D Axis lengths relative to one another
I am using a standard 3D Surface Plot and it works so far. However I would like to change the length of the scales relatively to one another so changing the scale ranges doesnt really help, because all I get is a lot of empty space then, because the overall window stays a cube.
I attached a picture to demonstrate what I mean.
I have this lenghty structure and changing the scales makes it look lenghty (left picture) but then the axes numbers are too far away. This is why I want different lengths of axis relative to one another. I changed it in paint by hand to demonstrate it. Its the picture on the right: The x-axis shall have at least double the length of the y-axis! How can I achieve that in Labview?
Daniel
(3,487 Views)
Hi Dani_Munich,
If you figure out the needed range of axis, you can change them in your program with propertyknots. I attached an example.
I hope this will solve your problem! 😉
(3,416 Views)
Hi Da44,
thanks for your reply 🙂
I dont have LabView 14 at the moment so I cant open the file unfortunately, could you save it as a LV13 or (older) version for me?
(3,385 Views)
(3,374 Views)
