01-16-2007 11:48 AM
01-16-2007 12:11 PM
01-16-2007 12:30 PM - edited 01-16-2007 12:30 PM
Just for you.
LV 8.2
Message Edited by Marc A on 01-16-2007 01:33 PM
01-16-2007 01:15 PM
Altenbach, thanks for the pointer. I play around with it, see what comes out the other end.
Marc, sadly, when I try to load the vi you attached I get a message it was written in LV 8.2 and won't load into 8.0
Regards, Mike
01-16-2007 02:10 PM
01-16-2007 03:24 PM - edited 01-16-2007 03:24 PM
Message Edited by altenbach on 01-16-2007 01:26 PM
01-16-2007 04:23 PM
I already ran across that problem playing with Marcs excellent example and was considering how to handle it. Your tip will save me some time. Thanks again.
Marc, thank you for your example. As a casual lv programmer, I have never needed to use property nodes. There is a lot more to LV than a casual use indicates.
Thanks again to you both. Mike
