Can i make an automatic Print screen in labview ?????
All people around these forums like Mike!
Smiley Very Happy
帖子被菁菁在05-30-2008 03:16 AM时编辑过了
Message 31 of 45
(5,599 Views)
Hi mike grt post.Thanx for the zip files.Works fine for me.
Message 32 of 45
(5,538 Views)
Yup we sure do!!!!Smiley Happy
Message 33 of 45
(5,499 Views)
Please ignore
Message Edited by muks on 06-16-2009 06:01 AM
Message 34 of 45
(5,289 Views)
Is there any chance someone could convert the Screenshot.zip Vi's to 7.1
Thanks all for all the help......
Message 35 of 45
(5,140 Views)
Hi Mike,
great VI's. I used them with LabVIEW 2009 SP1 without a problem (only had to reconnect some broken error-wires after conversion from LV 8.0). They work great, thanks.
Unfortunately they don't work with LabVIEW 2010. It crashes as soon your Kernel32.MoveBlock.vi tries to execute (at least on my XP it does). I guess it's a LabVIEW-Bug, what do you think?
Thomas
Message 36 of 45
(4,947 Views)
Hi Thomas,
you are correct. There is a mistake in the dll call. Please change the dll call in the "Move Block vi". It has to be a Win API call instead of a C call. With this change it works well for me in LV2010.
Hope it will also work for you.
Mike
Message 37 of 45
(4,933 Views)
Hi Mike,
thanks for you quick response. Changing the call method helped.
But I have another problem now: my executables crash as soon a SubVI containing your VI's gets loaded into memory (done with open-vi-reference). This happens with LV2009 and LV2010 executables. Do you have any clue why? Did you try your VI's with executables? Is there anything special I have to consider to use them with executables?
Thanks in advance,
Thomas
Message 38 of 45
(4,911 Views)
Hi Thomas,
i never tried the vi's in an executable. Did you delete the automatic copied dll, which are locate beside the exe in the data folder? Maybe this would solve the problem.
Mike
Message 39 of 45
(4,274 Views)
I've managed to print-screen and then save it as a png using the "write to png" built in sub-Vi. I then email the png gile to myself so that I may remotely monitor progress. However, I do this multiple times (in a loop) without stopping the VI. I've noticed that the files that are written remain open and in-use by Labview untill the VI stops. This is problematic, as, ideally, I'd like to simply write over the same png file. You can also imagine that, over time, so many image files in-use would consume a lot of memory.
Do you know of a way to create the png (or jpeg.. whatever) file such that the file is closed without closing the labview VI?
Message 40 of 45
(3,918 Views)
