Can I hide a cluster frame and all the controls to be seen
I am trying to hide the outline of a cluster while allowing the indicators to be visiable?
Can this be done?
(4,013 Views)
Yes it can. You use the paintbrush on the Tools palette. For details, you can see this post from a couple of days ago.
(4,012 Views)
The cluster found in the "classic controls" section does not use a sunken box as a graphic...it merely has a frame. If you use this...you can "paint" the frame transparent and you wont even know you have a cluster of controls on the FP...it will just look like a bunch of loose controls.
cheers,
-Brett Burger
(3,964 Views)
