Call a Labview DLL with Python: Access violation - what to do?
Hello forum users,
I wanted to create a Labview DLL for testing purposes. So I created a Labview 2012 DLL project with two simple VIs (one adds two input values and outputs the result, the other one multiplies them). This works fine so far.
However, if I call them from a Python 3.3 script, the Labview runtime seems to crash. What can I do?
Here is the Python code:
from ctypes import *
from sys import exit
lvdll = WinDLL("labview-testdll.dll")
add = lvdll.Addition
add.argtypes = [c_int, c_int]
add.restype = c_int
print("Addition von 3 und 3:", add(3, 3))
exit()
 The VIs look like so:
If I call this little Python script, I get this access violation error:
I attached the Labview project with the Python script in test-dll.zip. The crash log is also attached. Is this problem caused by Python or by Labview? What is wrong here?
(6,836 Views)
I just tried and it seem to work for me:
I used LabVIEW 2012 x86 and Python 3.3.0 x86. What are you using?
Best regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(6,790 Views)
I used Labview 2012 f2 32 bit and tested with Python 3.2.3 and 3.3.0 (both 32 bit).
However, I just updated my Labview 2012 to f3, and now it works. Maybe I was a victim of the faulty patch f2 (http://forums.ni.com/t5/LabVIEW/2012-f2-patch/td-p/2176250).
Anyway, thanks for testing! 🙂
(6,739 Views)
