Ask for help on how to stop a program in time when a subvi has to run in a relatively long time
For example, I want to time for a period in a subvi, say 10 seconds, and I want to stop the main vi in time. How to accomplish this task? Is there any examples I can refer to?
Message 1 of 8
(4,388 Views)
If you want to stop the main VI while a subVI is running, simply use the producer / consumer design.
While the consumer loop may be locked up by the subVI, you still can use the producer loop to set a shared variable to make the subVI stop.  Just add code in the subVI to check the shared variable.
George Zou
Message 2 of 8
(4,381 Views)
      The attached is one simple example I have seen:-
Thanks as kudos only:)
Message 3 of 8
(4,378 Views)
Look at another one:-
Message 4 of 8
(4,372 Views)
Hi danil,
- The 1st example has no features that stop the mainVI after a given period of time, so it doesn't fit as an example for the question...
- Your 2nd example doesn't work because it violates the dataflow paradigm. You can't exit the mainVI as the event structure is blocked by your subVI...
Do you also test your "examples" before posting them?
Do you ever read the question of the OP before posting unrelated VIs?
Message 5 of 8
(4,353 Views)
It seems to be working what we are trying.Can you please show the correct one that obeys dataflow paradigm.So that I can also study.
Sorry I just gave him a producer-consumer example.
Message 6 of 8
(4,348 Views)
Hi danil,
zou already explained how to program the solution.
I would just use a (functional) global variable instead of a shared one for simplicity...
Simplest solution using a global variable:
Message 7 of 8
(4,342 Views)
Hi GerdW,
               Thanks for your suggestion.
Message 8 of 8
(4,329 Views)
