9401 buffered digital output sample clock source
Hi, I wish to generate a pulse train with a defined number of pulses, at defined frequency. I am using a NI9401 module in slot 3 of a CompactDAQ chassis so that I can write the required pulse train to the 2047 sample buffer. The problem I have is I am unable to select any clock source slower than the 100kHz timebase, and this means the buffer can underflow very easily. I would like to use a clock source of 4kHz, but cannot find how to do it. If I want to generate a clock source from one of the counters, then I must have the 9401 in slots 6 or 7 which then do not allow buffered digital waveform generation..
(4,206 Views)
Accepted by topic author JPP
Hi JPP,
You can internally access the counters even though the modules are connected in slot 1-4 of the cDAQ chassis. Note that slot 6 & 7 are only necessary if you need external access to the counters as in buffered counter tasks, frequency/period measurements, etc.... Since in your application, all you need is to generate a continuous pulse train and access its output internally to clock your correlated digital output, this should not pose any problems with your DIO module in slot 4. Please have a look at the following link for more information.
Using Internal Counters on a NI cDAQ-9172 as a Sample Clock for Other Tasks
http://digital.ni.com/public.nsf/allkb/EEB574335BA0B4EB862572060055E9DD?OpenDocument
I would also like to refer you to an example on our site which shows you how to use the counter to clock your correlated digital I/O. I hope this helps.
NI-DAQmx: Correlated Digital I/O with NI CompactDAQ and LabVIEW
http://zone.ni.com/devzone/cda/epd/p/id/5256
S_Hong
(4,183 Views)
Thanks for that. Exactly what was needed.
(4,159 Views)
