2’complement hex convert
The data is in16bit, little-endian, 2’complement format.
Eg. “60 02” is a little-endian notation, it equals to 0x0260, 608 in decimal.
Also “FF FB” means -1025.
May I know how to do the convert in LV, the volumn is big.
Any suggestion, thanks.
Message 1 of 40
(9,374 Views)
Use the Swap Bytes VI under the "Numeric...Data Manipulation...palette. It will swap the upper and lower 8 bits of your word or array of words. You can then display it in whatever format you like.
Message 2 of 40
(9,368 Views)
Thanks, the  “60 02” is a string, and after swap, may I know how to convert further, thanks.
Message 3 of 40
(9,360 Views)
Sorry, thought you wanted to convert "endianess"....Swap Bytes doesn't work on strings.
Can you give an example of more than just two values so I can see more of the input formatting?
Message 4 of 40
(9,356 Views)
It is a string array displayed by '\' Code as attached.
Message 5 of 40
(9,354 Views)
Use string subset Vi to get lower and upper bytes.
Use concanet string to swap upper and lower bytes.
Use hexadecimal string to number conversion to convert it in decimal.
check the condition if it is greater than 65535 then subtract no. with this value to get negative no.
Labview user
Message 6 of 40
(9,353 Views)
Tried but cannot find 'concanet string', where is it, any suggestion, thanks.
Message 7 of 40
(9,346 Views)
That is your raw data - all the numeric values are there.  All you need to do is typecast the string to an array of U16 and then swap bytes (as previously), as shown below.  If you don't know where to find a certain function, search the palette using the search box (or search the help).
Message 8 of 40
(9,334 Views)
Sorry It was Concatenate Strings
Every function is under strings pallete
Labview user
Message 9 of 40
(9,329 Views)
Hi Natahand,
I think  typecasting would not show negative numbers.
Labview user
Message 10 of 40
(9,328 Views)
