LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Labview Lego Mindstorms 2015 incompatable with Mac OS X El Capitan?
I am unable to install the Lego Mindstorm module for Labview 2015. I don't know if this is a specific issue to me or if it is just not supported on El Capitan across the board. I was able to get the 2014 version to run the installation wizard up until it recognized that I have Labview 2015 and not 2014 so I don't know why the 2015 version won't work on my mac. Help would be greatly appreciated.
Message 1 of 9
(10,604 Views)
Hi AAkelly,
Could you provide more information about what actually occurs when you attempt to run the installation? Do you get any error? Does the wizard launch?
Additionally, could you make sure that you are using the installer from the following URL:
http://www.ni.com/download/labview-nxt-module-2015/5419/en/
Kyle S.
ni.com/support
Message 2 of 9
(10,583 Views)
As soon as the install wizard launches it pops up a window that states, "This product is not supported on the version of Mac OS X on this disk."
Message 3 of 9
(10,485 Views)
Hi Aakelly,
Unfortunately, it looks like Mac OS X 10.11 is not supported in LabVIEW 2015, and as a result the module is also not supported. Mac OS X 10.9 and 10.10 are supported for LabVIEW 2015.
A potential workaround would be for you to downgrade your Operating System to a supported version and then attempt to install LabVIEW 2015 and the corresponding module.
Please refer to the LabVIEW 2015 for Mac OS X README for Operating System compatibility information: http://www.ni.com/pdf/manuals/374717c.html
Kyle S.
ni.com/support
Message 4 of 9
(10,479 Views)
Labview 2015 is supported on 10.11. I have it and have been using it for several weeks.
Message 5 of 9
(10,470 Views)
Hi Aakelly,
According to the README for LabVIEW 2015 it is not officially supported in 10.11 and that is the reason you are seeing the message from the module installer. The fact that LabVIEW 2015 installed and that you can use it is not an indication that LabVIEW 2015 is officially supported for that Operating System.
Kyle S.
ni.com/support
Message 6 of 9
(10,466 Views)
Been able to run the EV3 and NXT on my late 2015 iMac with 11.11.4 beta.
Had to install a fresh Sylverlight and use the installer on the Lego website.
Message 7 of 9
(10,126 Views)
Would you please explain your procedure a little bit in detail? It will really help me a lot...
Message 8 of 9
(9,581 Views)
Hi All,
The LabVIEW 2015 Module for LEGO(R) MINDSTORMS(R) is not officially supported on Mac OS X El Capitan. To reflect this, the original installer for this version would display an incompatibility error and force you to close the installer:
However, we recently updated the installer to allow you to continue beyond this warning and install at your own risk despite the lack of official suport:
Just to reiterate, LMLM 2015 is still not offiically supported on El Capitan, but feel free to download the latest installer from here:
Thanks.
- Aaron
Message 9 of 9
(9,545 Views)
