LabVIEW MathScript RT Module
mathscript error
Dear friends,
I just want to use mathscript to finish a simple function as:
MASK0=hex2dec('00');
WIRE_bit(1:32)=bitget(MASK0,1:32);
I think the WIRE_bit should be 0, however the result show that it is 1.
Then I change the code into:
MASK0=hex2dec('F0');
This time I can get the expected results.
The attchment is the vi and the result picture. Who can give me a answer?
Best Regards
Jim
(7,172 Views)
This is a documented bug in LabVIEW 8.2. It works correctly in LabVIEW 8.5.
(Look for ID=3ZREKDKQ and ID=45RB7L1Y here: http://zone.ni.com/devzone/cda/tut/p/id/6448)
Message Edited by altenbach on 04-27-2008 09:35 PM
(7,167 Views)
Thank you dear friend.
(7,161 Views)
