LabVIEW MathScript RT Module
dlmread crashes
I am trying to read  some files ( around 50 of them)  in a loop.I have used this dlmread in mathscript . To load the data in each file , i use dlmread.
It works fine for some iterations , like around 20. But if i increase the iterations to say 50, then it crashes with a error code..(.Error -90001 occurred at Error in function dlmread at ....)
This code works perfectly fine in matlab..for 150 files .
Could anyone please suggest a solution to this ,
Many Thanks.
(6,603 Views)
Would you please attach your code? Then, I could investigate the problem.
Thanks!
(6,598 Views)
