LabVIEW MathScript RT Module
User defined function error in Labview mathscript
 I m Labview 2011 user. I had a problem when i use a user defined func in mathscript.
 I have used it well, but it doent work suddenly. It looks like below.
 function name turned to grey color suddenly. Plz help me.
(9,402 Views)
Did you change the search path for .m files in the LabVIEW options (mathscript section)?
(9,395 Views)
The last time I dealt with this, it was very confusing.  If I remember correctly, there were 3 different places that I had to set the correct search path for the .m file:
1) Tools>Options>MathScript
2) In the Project, right-click on My Computer and select Properties>MathScript
3) Tools>MathScript Window>File>LabVIEW MathScript Properties
The documentation seems to indicate that at least 1 and 2 should be the same and 3 only applies to that window, but like I said, last time I did this I remember having to change all three.
Good luck!
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(9,387 Views)
LABVIEW mathscript is having limited MATLAB command. Threrefore, it creates problem in some of  the command.
(9,234 Views)
hi
i have problem to add function in mathscript node
i add .m file from tools>option>mathscript , but i have error for func name
it`s necessary, pleas help me
thank
(7,372 Views)
