LabVIEW Communications System Design Suite
LabVIEW Communications 1.1 is LIVE!
Hey All!
LabVIEW Communications System Design Suite 1.1 is now live!
I highly recommend upgrading.
Thomas C.
FlexRIO Product Support Engineer
(5,593 Views)
Hello tcap,
i have just installed the software packet but it seems to be just the basic version and not the entire suite. The LTE and 802.11 frameworks (1.1) are also missing.
Is the full suite also available?
(5,528 Views)
Hey labviewette,
When you install LabVIEW Communications from the above link, it does not install the Frameworks by default.  You need to explicitly tell it to install them.  I recommend going through the installation process again and having it modify your installation to include the Frameworks.
Can you please provide me with a little more information about what is broken in the basic version/suite?  How does it show up in NI License Manager?
Also, take a look at the following White Paper about upgrading your applications.
https://www.ni.com/en/support/documentation/supplemental/15/lte-application-framework-1-0-behavior-c...
Thomas C.
(5,502 Views)
