LabVIEW Communications System Design Suite
Implementing cpp code in LVCS
Hi everyone! Is it possible to integrate cpp code into Labview Communications?
In original Labview it was possible via "library function node" but there is no such node in LVCS. Ofcourse there is a  C Node but is useful only in simple applications, if I am right.
(3,802 Views)
Accepted by topic author Xkela
Hi Xkela!
Unfortunately, this is not a feature in LabVIEW Comms at the moment. At best, you'd be able to use the C node as you noted, or you can use the System Exec node to call the DLL from the command line.
Stephen Chan
(3,776 Views)
