02-14-2014 12:46 PM
when i use exe file ....this message which is attached appears
what is meaning this message
02-14-2014 02:29 PM
02-14-2014 04:08 PM - edited 02-14-2014 04:10 PM
i sory for late........
yes i aborts my program ....
02-14-2014 06:29 PM
02-14-2014 07:32 PM
HOW CAN I STOP ?
02-14-2014 08:27 PM
02-15-2014 02:06 AM - edited 02-15-2014 02:08 AM
in my program i reading datat from serial port ......and if i exit from programm this message will appear .....how can i cancel this message ?
02-15-2014 02:27 AM
It does not really add to the discussion if you keep attaching the same image over and over, so stop that! Thanks.
Show us your code and tell us exactly how you "exit from the program". The root cause is in your program and how you (ab)use it, not in the dialog you keep showing us.
You cannot cancel that message, but you should be able to clean up your code so it no longer happens. For more information, have a look at this article.
02-15-2014 02:54 AM
ok ....i will send the code for you in private message
