n6700 query max current is timing out
I have the N6700 chassis and have installed the IVI driver for it.  I have two different modules in the chassis.  Both exhibit the same issue.  I initialize them, which works fine.  I disable the outputs, and then query the max voltage level.  All this works and retunrs good data.  Then I try tyo query the max current.  I have tried with both the IVI function as well as the driver specific function.  Both timeout.  I have tried passing 0V, 20V, and the output from the max voltage back into its voltage input.  It doesn't like the 0V, the other two options just timeout.  I use this same routine to querya couple E363x supplies and it works fine on them.  Any thoughts on why this specific VI isn't working?
(5,791 Views)
Does the instrument have any errors after the timeout?  Make sure you do a querry for all of the errors from the instrument.  That will usually key you into the problem.
(5,790 Views)
I get two errors.
GPIB: Error -101, Invalid character
GPIB: Error -420, query unterminated
Is there something wrong with the IVI driver?????
(5,786 Views)
Accepted by topic author Muffin
OK, it was the driver again.  I am not going to download any more drivers off NI's website.  That is the third bad driver I have gotten from them.  Got the correct one off Agilents website and it works fine.
(5,783 Views)
You can turn on IO Trace in MAX and capture the command being sent. Compare that to what is listed on the manual.
(5,781 Views)
