how to program USB-6009 with visual C++ - Intro
Hi there.
Can anyone give me some hints on how to start coding for USB-6009 in Visual Studio C++?
is it even feasible OR should I use the .NET version?
Thanks very much for any help.
s.
(7,116 Views)
Hello saamooraaii,
There are a couple of resources that should already be on your system that you can use. Once you have installed NI-DAQmx you will also have the DAQmx C Reference Help, found under Start»All Programs»National Instruments»NI-DAQ»NI-DAQmx C Reference Help. This document has a comprehensive listing of all available DAQmx C function calls. Another resource would be the examples found on your computer under NI-DAQ\Examples\VisualC. There are several examples in this directory that should help to get you started.
For more information on getting started with NI-DAQmx in a text-based environment you should check out KnowledgeBase 18G6G34S: How do you Compile and Run NI-DAQ Examples with Microsoft Visual Studio?
Dan King
(7,089 Views)
Thanks Dan,
I am currently checking out the
resources you sent me.
s.
(7,086 Views)
