 alba
			alba
			10-19-2005 10:49 AM
 Makoto
			Makoto
			10-19-2005 07:31 PM
I believe you are running old Win16 (16bit Windows such as Windows 3.1) program. The 16bit GPIB.DLL is provided for backward compatibility to old 16bit GPIB apps and operates with universal thunk or generic thunk mechanism, redirecting every NI-488.2 function call from/to GPIB-32.DLL.
The correct location for 16bit DLLs under Win2NT/2k/XP platform is <WinDir>/System, not <WinDir>/System32.
10-20-2005 04:18 AM
Hello makoto, thank you for your reply.
I have changed the following line (and all the similar...) in the VBIB.BAS module
Declare Function route_IBDEV Lib "gpib.dll" (ibsta%, ByVal bdid%, ByVal pad%, ByVal sad%, ByVal tmo%, ByVal eot%, ByVal eos%) As Integer
 Makoto
			Makoto
			10-20-2005 04:37 AM
I thought you are attempting to run a 16bit VB (version 3 or older) program with the true or thunk-layered 16bit GPIB.DLL, but what you are trying is operate an old VB program with source codes (originally written for 16bit GPIB.DLL) converting into VB6 under today's platform (Win2k/XP) with the GPIB-32.DLL. Sorry for my misunderstanding.
In your case, you don't have to modify the VBIB.BAS file. Instead, just replace VBIB.BAS with VBIB32.BAS in your VB6 project. The VBIB32.BAS declares GPIB-32.DLL public functions for VB6. Because the NI-GPIB API is kept unchanged for its syntax for GPIB-32 version, any GPIB calls in the old VB program will be source-code compatible with the new VBIB32.BAS.
The VBIB32.BAS is automatically installed with the NI-488.2M Win32 drivers, so you will find it in the NI-488.2M installation directory.
Makoto
