06-24-2008 03:38 AM
06-25-2008 05:48 AM
Hi Dan,
Most functions seen in the FPGA palette when you are targeted to the FPGA can be used in a Single-Cycle Timed Loop (SCTL). The following is a list of notable exceptions. These functions will not work inside the SCTL:
I believe this is the reason that you are seeing this behaviour,
All the best,
06-25-2008 07:45 AM
Ah, sorry it was the wait on occurances which were not triggering correctly.
The occurances themselves were being triggered correctly
I have found the source of the problem:
The event itself was locking the loop, except under certain rare conditions, which I happened to trigger the first time I ran it each session.
The occurances and wait on occurances were working as they should have according to the manual.
Embarrassing as always
Thanks for the help
Dan
06-25-2008 07:55 AM
Hi Dan,
No problems at all, normally with these things it turns out to be something thats obvious yet very good at not being seen, I'm glad your applications up and running now!
Thanks for letting me know,
All the best,
