Serial ports (via USB) get blocked (?) - do I need to disconnect them?
I am running LV 7.1, using VISA config, read, write etc. to communicate through serial ports. For this purpose, I have a USB to serial converter, 8fold, which gives me eight serial ports.
It seems that, when the computer has been rebootet, I am able to use the serial ports, but after a while, when configering and reconfigering them, they get unusable.
Is it necessary, once a serial port has been configured, to release it, so it can be used for another configuration/funciton?
Is there a VI to release a serial port?
Thanks for your help!
(2,888 Views)
There is also a VI to close the VISA-Session called "VISA Close". Use this function after you have done all the work with your COMs. Maybe it helps !
Greetings Heimo
(2,843 Views)
we are using USB for a Touch controller. After a little time it can be possible that the USB is also blocked.
We found two reasons for this:
1) The power options of the computer. If they are available and the computer tries to power down, the USB connection get blocked. (If a application is running the power options start to shut down the computer but the application denies this.)
2) Electro magnetical interference with other devices
Perhaps it helps
Greetings
Oliver
(2,808 Views)
