09-06-2007 01:37 AM
09-06-2007 04:34 PM
09-06-2007 11:29 PM
Thanks Scott,
Some clearance beforehand, I am developing an application on my PC which is solely NI (Visa, LabView, 488.2 etc). The target PC has no LV but uses Agilent USB-GPIB to run internal Agilent controling SW, they are using the Agilent-Visa.
I am using in my application justSCPI-commands wired to a VISA read/write instead the drivers of the AGILENT device.
I guess I will need only the LV runtime engine on the target PC and no NI-VISA nor NI-488.2. Am I correct?
Regards
Y3G
09-07-2007 07:22 AM
@Flocko 4040 wrote:Hi,The Agilent Visa and NI Visa should be able to exist side by side. First Install NI-Visa. Install the "Agilent IO Libary Suite" program afterwards with default settings. There should be an entry in the Agilent-main panel saying: "Agilent Visa is the secondary visa" Enable the Tulip passport. Now all commands for Visa in LabVIEW should be working for serial and GPIB. That's the way it is working with my computer and a Agilent USB-GPIB converter.
09-07-2007 08:20 AM
I think Flocko4040 is correct in his statement. You will need the Agilent VISA to communicate through your Agilent card. But you will also need any of the drivers that you are using in your LabVIEW coding. So if you are using NI VISA VI's in your coding you will need the NI VISA driver. If you were using the DAQmx driver (which you probably are not) then you would also need that runtime.
