11-22-2007 10:04 AM
11-22-2007 10:17 PM
A printer port is not a serial port at all. If the instrument only supports a serial connection and you don't have one on the laptop, you should buy an inexpensive USB-RS232 converter. I strongly doubt that the device supports an *IDN? query or VISA either. That's usually only for instruments that also have a GPIB connection option.
As far as the downlevel VIs, with 8.5, the earliest VIs it will open is 6.0. If you have any version of LabVIEW prior to 8.5, you can open them and save them to something 8.5 can open. Otherwise, you might want to either ask IOTech to upgrade them for you or post the VIs and ask someone here to do it.
11-23-2007 03:11 AM
Hi yeah thats pretty much exactly what I was fearing! Think its best to find some other way round then!
Thanks for your help!
Jon
