How to create the VXI11 interrupt channel while client is running on NI-Max Client.?
Hi All,
From below threads I just came to know that there is no port-maper service on NI-VISA client hence I have implemented the raw socket for the same.
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-VISA-on-Windows-2000-PC-and-Port-Mapper-Se...
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Does-VISA-have-VXI-11-Server-implement-to-ser...
I am able to establish interrupt channel with NI-Max client but still I am not getting VI_EVENT_SERVICE_REQ  event at client side  and viWaitonEvent() function giving timeout.
Might be there is some issue with new defined RPCHDR structure!!
I never done Network programing before. Please guide; how to resolve this issue.
client Socket Code:-
typedef struct rcphdr{
 unsigned int length;
 unsigned int xid;
 unsigned int msg_type;
 unsigned int rpcvers;
 unsigned int prog;
 unsigned int vers;
 unsigned int proc;
 unsigned int auth[4];
}RPCHDR;
typedef struct DeviceSrqParms {
 struct  {
  u_int handle_len;
  char handle_val[40];
 }handle;
}DeviceSrqParms;
typedef struct intr_srq_data
 RPCHDR    tdsRPC_Header;
 DeviceSrqParms  tdsDevSrqData;
}intrsrqData;
static SOCKET ConnectSocket;
struct sockaddr_in clientService;
WSADATA wsaData;
intrsrqData SrqMsgStruct;
unsigned int toBigEndian(unsigned int val)
 if(!isBigEndian())
  return htonl(val);
 return val;
create_intr_chan_1_svc(Device_RemoteFunc *argp, struct svc_req *rqstp)
 int iResult = WSAStartup(MAKEWORD(2,2), &wsaData);
 if (iResult != NO_ERROR)
  printf("Error at WSAStartup()\n");
 ConnectSocket = socket(PF_INET, SOCK_STREAM,0);
 clientService.sin_family = AF_INET;
 clientService.sin_addr.s_addr =  inet_addr( "127.0.0.1" );
 clientService.sin_port = htons(argp->hostPort);
 if ( connect( ConnectSocket, (SOCKADDR*) &clientService, sizeof(clientService) ) == SOCKET_ERROR) {
  printf( "Failed to connect.\n" );
  printf("Error at socket(): %ld\n", WSAGetLastError());
  WSACleanup();
  return;
#endif
device_enable_srq_1_svc(Device_EnableSrqParms *argp, struct svc_req *rqstp)
 static unsigned int ui32XId = 1;
 std::string handle = std::string(argp->handle.handle_val, argp->handle.handle_len);
 unsigned int     ui32Length = (sizeof( RPCHDR ) - 4) | 0x80000000;
 SrqMsgStruct.tdsRPC_Header.length = toBigEndian(ui32Length);
 SrqMsgStruct.tdsRPC_Header.xid = toBigEndian(1);
 SrqMsgStruct.tdsRPC_Header.msg_type = toBigEndian(0);
 SrqMsgStruct.tdsRPC_Header.rpcvers = toBigEndian(2);
 SrqMsgStruct.tdsRPC_Header.prog = toBigEndian(DEVICE_INTR);
 SrqMsgStruct.tdsRPC_Header.vers = toBigEndian(DEVICE_INTR_VERSION);
 SrqMsgStruct.tdsRPC_Header.proc = toBigEndian(device_intr_srq);
 memset(SrqMsgStruct.tdsRPC_Header.auth, 0, sizeof(SrqMsgStruct.tdsRPC_Header.auth));
 //Append stored SRQ data
 strcpy(SrqMsgStruct.tdsDevSrqData.handle.handle_val,handle.c_str());
 SrqMsgStruct.tdsDevSrqData.handle.handle_len = toBigEndian(VxiIOConst::Handle.mHandleLen);
 //TCP Socket accept data as std::string, so convert data structure to std::string
 char *pcData = (char *) &SrqMsgStruct;
 int iResult = send( ConnectSocket, pcData, sizeof(INTR_SRQ_DATA), 0 );
System Info:-
Operating System(OS)                Microsoft Windows XP Professional
OS Version                          5.01.2600
OS Info                             Service Pack 3
Processor                           Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz / x86 Family 6 Model 23 Stepping 10 / GenuineIntel / 2992 MHz
Number of Processors                2
Physical Memory                     1.85 GB of RAM
Drive C:\                           72.4 GB of 97.6 GB free
Drive E:\                           115 GB of 135 GB free
National Instruments Software:      Version:
CVI Run-Time                        9.0.0.353
LabVIEW Run-Time                    8.2.1
Measurement & Automation Explorer   4.5.0.49152
NI-PAL Software                     2.4.0
NI Spy                              2.6.0.49152
NI-VISA                             4.5
     NiVisaServer.exe               4.5.0.49152
     NIvisaic.exe                   4.5.0.49152
NI-VISA Runtime                     4.5
(3,589 Views)
Hi C++Coder,
You don't have to send back the package in function device_enable_srq_1_svc, you only store the package in memory and also detect it is send by the system with what Endian (Big or Little).  When the STB bit RQS (bit-6) raised (for testing you could simulate it), you send back the stored package in function as described in my thread with Endian handling, so it'll work for any system.
(3,582 Views)
