first, yes I read that Mandriva 2008 is not (yet) supported, but I thought I give it a try as for Mandriva 2006 nothing is continued, which makes it a pain to configure and use it.
Labview8.2 went through like a charme. Also NIKAL 1.6. But when I try to install VISA 4.2, I get following error message, which seems to me just a little clitch that could be fixed easily?
The following components will be installed using rpm:
NI-VISA Runtime 4.2.0 3199 KB (in /usr/local/vxipnp)
NI-VISA Development 4.2.0 9303 KB (in /usr/local/vxipnp)
NI-VISA Configuration 4.2.0 524 KB (in /usr/local/vxipnp)
NI-VISA Server 4.2.0 250 KB (in /usr/local/vxipnp)
PXI Services 1.6.0 791 KB (in /usr/local/natinst/nipxi)
NI Spy 2.5.1 2286 KB (in /usr/local/natinst/nispy)
CVI Runtime 8.0 8554 KB (in /usr/local/natinst/cvirte)
LabVIEW Runtime 8.2.1 38472 KB (in /usr/local/lib/LabVIEW-8.2)
NI-ORB 1.7.0 481 KB (in /usr/local/natinst/.nicore)
NI-DIM 1.7.0 585 KB (in /usr/local/natinst/.nicore)
NI-RPC 3.4.0 123 KB (in /usr/local/natinst/.nicore)
NI-PAL 2.1.0 1843 KB (in /usr/local/natinst/nipal)
Total space required: 66411 KB
Space available: 2143032 KB
Continue? [Yn]
Installing selected components ...
error: open of /tmp/nivisa.install/nipal/nipali-2.1.0-f1.i386.rpm /tmp/nivisa.install/nirpc/nirpci-3.4.0-f1.i386.rpm /tmp/nivisa.install/niorb/niorbi-1.7.0-f0.i386.rpm /tmp/nivisa.install/nidim/nidimi-1.7.0-f0.i386.rpm /tmp/nivisa.install/nipxirm/nipxirmi-1.6.0-f0.i386.rpm /tmp/nivisa.install/nicvirte/nicvirte-8.0-6.i386.rpm /tmp/nivisa.install/lvruntime/labview82-rte-8.2.1-2.i386.rpm /tmp/nivisa.install/nivisa/nivisa-4.2.0-f1.i386.rpm /tmp/nivisa.install/nivisa/nivisa-devel-4.2.0-f0.i386.rpm /tmp/nivisa.install/nivisa/nivisa-config-4.2.0-f0.i386.rpm /tmp/nivisa.install/nivisa/nivisaserver-4.2.0-f1.i386.rpm /tmp/nivisa.install/nispy/nispyi-2.5.1-f0.i386.rpm failed: No such file or directory
* A reboot is required before attempting to use the NI-VISA software. *
Would you like to reboot now? [yes|no] no
Installation completed successfully.
Please reboot manually before attempting to use NI-VISA software.
Sure enough I cannot see any of these files in /tmp/, but I am root when I try to install VISA. the nikaliPostInstall.log is for example also there in /tmp/.
Also VISA is certainly not installed as updateNIDrivers only sees NIKAL installed, even though it says installation successfull.
Hope someone can help
Cheers
Thomas
