Computer recognized PCIe-GPIB but not PCI device
In NI MAX and windows device manager, I have the PCI-GPIB device, but it can not recognize the PCI 6713 and PCI 6733 that are connected.  Both of the PCI devices have a green LED that flashes for about a second every couple seconds.  Everything is connected and powered as it should be.  Thanks for any help.
Message 1 of 10
(5,650 Views)
The GPIB card has nothing to do with either the 6713 or 6733. Why do you even mention it?
Have you installed DAQmx?
Message 2 of 10
(5,645 Views)
I did not know that they were not related in any way.
Yes I have installed that
Message 3 of 10
(5,639 Views)
What version? Are you still not seeing them listed in device manager or MAX?
Message 4 of 10
(5,626 Views)
9.5.1.  And I do not see it in the device manager, or MAX.
Message 5 of 10
(5,622 Views)
Message 6 of 10
(5,615 Views)
I just installed 15.1 and there is still no recognition of the devices.
If it helps, I have a pci extender from my computer to a homemade box that connects to both devices
Message 7 of 10
(5,603 Views)
The extender is probably the problem. You should have mentioned that in the first post. I've not seen extenders used successfully and NI does not test or recommend any.
Message 8 of 10
(5,597 Views)
The 'extender' we use is just a PCI Express 4-Port 4-Lane Packet Switch (XIO3130) from TI.  Is that still problematic and an explanation for why we cannot see the devices?
Message 9 of 10
(5,589 Views)
If you can detect the cards when plugged directly into a pc, then yes.
Message 10 of 10
(5,585 Views)
