07-31-2013 04:28 PM
I am using a Chroma 61604 AC power Source. The driver which I am using can be found here: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9172659CE034080020E748.... I am connecting it to a computer running Windows XP through a USB serial adapter. The driver says it is GPIB compatible. When trying to communicate to the device I get the following error:
Error: BFFF0072
Reference valid but VISA cannot currently access it.
I am not very knowledgable in creating drivers, how can I modify this driver to be serial compatible (if that is the problem)? Or do I need to use a GPIB to USB converter?
Thanks for your time,
Kyle Goyette
08-01-2013 08:50 PM
Hi Kyle,
The BFFF0072 error is indicating that the serial port you are trying to configure is being used.
Moving forward:
Please update on if this helps you move past the error.
