CV Measurement with HP 4280A
Dear Friends,
we are a group of students who are building a measurement system with HP 4280A, everything worked fine until we wanted to read the buffer.
When we read the buffer as shown in the picture above after sending the necessary CV measurement string (FN1,CH,MS3,SL2,LE1,FL,CNI0,IB3,PL0.03,R3,MA1,TR3,PS)  after this we want to read the bbuffer as seen on picture.
but we only see the last measurement result out of 100...
any help will be deeply appreciated...
best regards
Message 1 of 22
(7,722 Views)
You can use or refer to the example that comes with LabVIEW
\Program Files\National Instruments\LabVIEW 8.2\examples\instr\smplgpib.llb\LabVIEW<->GPIB.vi
Message 2 of 22
(7,695 Views)
I need you to help me about a Capacitance-Voltage program that controls the HP 4280A 1MHz C-V Plotter. So, I need an instrument library that I didn't found until now and if any of you had a C-V program working with the instrument mentioned above, please send it to me or give me how to read the C-V data via the GPIB link from the instrument.
Important Note: I have done C-V measurement with HP 4280A manually. All the commands are executable except those of reading the data in Agilent Vee Pro software.
please give me how to read the C-V data.
Thank you in advance.
Message 3 of 22
(6,879 Views)
If you are using VEE then try to ask Agilent
For LabVIEW look at instrument driver net
http://search.ni.com/nisearch/app/main/p/ap/tech/lang/nl/pg/1/sn/ssnav:idr/
greetings from the Netherlands
Message 4 of 22
(6,839 Views)
The HP 4280A C-V Plotter is obsolete as Agilent said. so, it doesn't exist a driver for the instrument.
If anyone have a C-V program of HP 4280A, please send it to me as soon as possible.
Thank you.
Message 5 of 22
(6,828 Views)
I have CV measurement program
But I don't have C-T mode program
Message 6 of 22
(6,664 Views)
Please send the CV program to me via this email: fargi.abdelaali@gmail.com
Thank you very much.
Message 7 of 22
(6,654 Views)
Please, I am waiting for your help.
give me the program of C-V Measurement with HP 4280A.
Message 8 of 22
(6,626 Views)
Message 9 of 22
(6,618 Views)
Thank you for help, but there is a missing SubVI in the program.
Could you bring to me all dependent VI in the whole program PLEASE.
send them to me in a zip file.
Message 10 of 22
(6,591 Views)
