06-29-2006 04:43 PM
06-30-2006 11:50 AM
06-30-2006 01:17 PM
06-30-2006 02:16 PM
Exactly right. If you had a 64 bit app, then we would need to have 64 bit user-mode libraries available.
As for the API, I'm not sure... I suspect for the short run 32-bit would work as we have a 32-bit app. But if I understand the distinction right, in the near future we'd need a 64-bit one (when we ported our actual application to 64-bit.) Am I making the right distinction on what API would be needed or is there some other deciding factor?
06-30-2006 04:19 PM
Unless demand increases, we will likely have 64 bit Linux drivers when you can actually put more than 4 GB of RAM in a desktop class machine (currently you have to buy a workstation or better to get a motherboard that even supports more than 4 GB), and/or 64 bit Operating Systems become the standard.
07-07-2006 08:55 AM
