Industrial Communications
Change PDO mapping in EtherCAT
is it possible to change the PDO mapping of an EtherCAT slave during runtime ? The questions was already asked at the post Setting the PDOs in an EtherCAT Slave. But it is nor clear if it is now possible or not.
Message 1 of 8
(11,287 Views)
Not with an NI EtherCAT slave (i.e. 9144 / 9145).
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
Message 2 of 8
(11,221 Views)
And it is possible to change it for third party EtherCAT slave?
Message 3 of 8
(11,215 Views)
Message 4 of 8
(11,208 Views)
This method i allready now. But I will change my PDO mapping during runtime. If you go through the post i added in my first answer you will find the following message:
"You do not do this by changing or modifying the XML file. If fact, the file should never be changed.
In TwinCAT, you can change the PDO selection with a few mouse clicks and this does not change the XML file whatsoever.
In order to reach the full features of a bus terminal, you must be able to change the PDOs. Otherwise, the end customer will not be able to use all of the features of EtherCAT."
The post is 4 years old and my question is if it is now possible to change the PDO mapping and find the changed PDOs then programmatically during runtime. Because if I change the PDO mapping during runtime using SDO commands then by searching for the changed PDO i am not able to find them.
best regards,
Daniel
Message 5 of 8
(11,204 Views)
Accepted by topic author daniel59
Sorry for missing your original post. In that case, I am afraid there is still not a method to change the PDO mapping of an EtherCAT slave during runtime.
Message 6 of 8
(11,198 Views)
I know this is an old post, but did you find a work-around for this problem?
Message 7 of 8
(8,929 Views)
any update about this old but really interesting issue?
Let us know,
FDA
Message 8 of 8
(6,441 Views)
