Is there a way to pause PXI-6541 once it has started data generation by using the PFI
lines? I want to use a PXI 6541 to send test data to a downstream compression chip which,
depending on setup, might delay in processing the input data. I would like to route
the half full flag of the compression chip  back to the PXI- 6541  to pause the PXI6541
generating data if data starts to back up in the input buffer of the comression chip (using
a PFI line). I would also route another  PFI line to the valid data input of the compression
chip to denote vaild data.
I am using niHSDIO C calls to implement the generation but I can not find any examples
 of doing this.
NIHSDIO_ATTR_PAUSE_TRIGGER_TYPE  is defined in niHSDIO.h but I am not sure
what this is used for.
Any help would be appreciated,
David.y.fisher@nasa.gov
