FieldPoint Family
Connection to cFP-AO-210
Dear all,
I have a question on how to connect loads to a cFP-AO-210 module. According to the operating manual, the maximum current for the loads connected via an external power supply is 10 mA. Is there any way that you know of to build an external circuit (for example with transistor) that I can connect to a load, to overcome such limit?
Thank you in advance,
Valeria
(4,265 Views)
You can connect a relay to the output and then connect the load to the relay!
To connect a relay to a circuit you can look at this post: http://www.buildcircuit.com/how-to-use-a-relay/
(4,248 Views)
