Example Code
Shutdown Windows in LabVIEW (2 Different Methods)
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example illustrates 2 methods for shutting down Windows from within LabVIEW.
Description
Method 1:  Using the System Exec VI
Shutdown is achieved by passing the system-level command: cmd.exe /C shutdown -r -m \\computername -t 5 -f
This command translates to shutting down the computer (named computername) with a timeout of 5 seconds, forcing all running applications to close without warning.
Method 2:  Using the Call Library Function Node
This method accesses the user32.dll and utilizes the ExitWindowsEx function to perform a Windows shutdown. Drop a Call Library Node (CLN) and configure it as shown in the following picture. uFlags set to zero forces a shutdown of all processes and then logs off the user; setting dwReason to zero indicates the reason for shutdown is related to "some other issue." If the function return is not equal to zero, then the function executed successfully.
Requirements
  • LabVIEW 2012 (or compatible)
Method 1
  1. Open System Exec to Shutdown Windows 2012 NIVerified.vi
  2. Input your computer name into the "computername" control
  3. Run the VI AFTER checking that your computer and work in progress is ready for a forced shutdown.
Method 2
  1. Open Call Library Function Node to Shutdown Windows 2012 NIVerified.vi
  2. Set the value of uFlags, dwReason to default value 0
  3. Run the VI
You should always consider protecting code like this with dialogs that allow users to save and close things a they see fit prior to a shutdown.
VI Snippet of System Exec to Shutdown Windows 2012 NIVerified
VI Snippet of Call Library Function Node to Shutdown Windows 2012 NIVerified
Sara Lewandroski
Applications Engineer | National Instruments
