Example Code
Scale Color Panes from a Color Image in LabVIEW without using the NI Vision Development Module
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates how to extract the red/green/blue color plane from a color image, scale the panes and show the results.
Description
This VI use the numeric data manipulation to split the 2D array in the color-representing u8 arrays.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached ZIP-file
  2. Open the VI and follow the instructions inside
Scale Color Planes From A Color Image LV2012 NIVerified.vi - Front Panel.png
Scale Color Planes From A Color Image LV2012 NIVerified.vi - Block Diagram.png
  **The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Vince M
