Overview
This example shows how to manually control aperture time for a DMM in LabVIEW.
Description
When a DMM is set to Auto-Range, it may not take advantage of all of its digits of resolution. For instance, the 4065 is a 6.5 digit DMM; however, when the DMM is used in Auto-Range mode, only 5.5 digits are used. The Aperture Time Property Node can be used to increase the aperture time to the match the aperture time for 6.5 digits so that Auto-Range can be used but a 6.5 digit measurement can be obtained.
Requirements
Software
LabVIEW 2012(or compatible)
NI-DMM driver which is compatible with your hardware and version of LabVIEW
Hardware
NI DMM Device
1. Download and open the example VI
2. Configure the following settings in the block diagram:
3. Run the VI
4. Observe on the front panel the aperture time for 5.5 and 6.5 digits
Block Diagram
