Example Code
Programmatically setting range for multiple scales
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview: This VI demonstrates how to use Graph Property Node to change its properties.
Description: When you have a program that involves a waveform graph with multiple scales, it is possible to set the range for these scales programmatically through property nodes.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Change the settings.
2. Run the VI.
3. Look how the graph is changed after running the VI.
Additional Information or References:
Misha
