Example Code
Programmatically Set A Graph Scale To Linear Or Log
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how you can use a graph property node to set a linear or log scale.
Description
LabVIEW offers options to configure the scale of a graph to a linear or log scale. It is possible to configure this static trough the LabVIEW-IDE, but it is also possible to change the scale during the execution of the VI.
This example demonstrates how to change the scale during the execution of the VI.
Requirements
 Software
  • LabVIEW Full Development System 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached VI
  2. Run the program
Additional Information or References Change Graph Scale During Runtime - Front Panel.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
