Example Code
Programmatically Change Visible Plots on Waveform Graph Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI demonstrates the capability of using a custom interface in order to alter the visible plots on a waveform graph.
Description
This provides a more intuitive experience for the user while the program is running, and it ensures the visibility of each plot can be toggled without the presence of the plot visibility check box. The bottom loop with the three Simulate Signal VIs demonstrates the capability of this VI. The contents of this bottom loop can be changed in order to view any data desired on a multiple plot waveform graph.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the VI "Programmatically Change Plot Visibility 2012 NIVerified.vi"
  2. Run VI
  3. Click control buttons such as Disable Plot 1, Disable Plot 2, or Disable Plot 3
  4. Click control buttons such as Enable Plot 1, Enable Plot 2, or Enable Plot 3
VI Block Diagram
Sam Burhans
Senior Product Manager
Comments
mfh721
Member
Member
on
Both of the VI's above seem to be 2013 versions.
CoffeeBreak
NI Employee (retired)
on
Thank you mfh721, I have uploaded the correctly saved version for LabVIEW 2010. Sorry for the mishap
Sam Burhans
