Overview
Code that plots new random data on a specific amount of iterations.
Description
If your system requirements stipulate that data should be amassed from multiple acquisitions then plotted only when a certain number of acquisitions have been made, you can use the remainder of the iteration count to only plot on the 5th, 200th, etc. multiples of the loop count. This might require you to accumulate data in a shift register between writes. This code demonstrates this idea.
Requirements
1. LabVIEW 2012 (or compatible)
1. Run the VI
2. Monitor the Size of Array indicator
3. When desired, finish the execution with the Stop button
Additional Information or References:
Verne D. // Software R&D // National Instruments
