Example Code
Convert a Hex String to ASCII String & IEEE Float without changing values
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts a displayed Hex String value to ASCII string characters as well as IEEE Float.
Description
Sometimes it maybe desirable to convert a String Hex Value to ASCII but not actually change its representation. For example, we may have the value 6C in hex and we want it in ASCII to also be 6C. This VI will do this conversion. It takes the Display Hex String and converts it into regular string characters. I eventually needed the IEEE Float value for that Hex String value, so the last part converts it to IEEE float.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Give the value of Hex Number Display Input (i.e. 3643 3133 3435)
  2. Run the VI and observe the outputs.
Front Panel
VI Snippet
Certified LabVIEW Developer
LabVIEW 7.1 - Present
Comments
shall12
Member
Member
on
Worked for me after I changed the type for the Unflatten From String to a U8.
GPeople
Member
Member
on
YES!  Actually I remember making a VI for each data type..I have them somewhere...if I find them I will upload each type.
If I had the time the thing to do would be to make this into a polymorphic VI so it would sense the data type and then execute the proper version.
Glad to see it helped someone!
