Example Code
Find Line Length or Distance Between Two Points in an Image
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to calculate the distance or length respectively between two points or a line of an IMAQ Image Region of Interest (ROI).
Description
The example shows how to use the Region of Interest (ROI) tools for an IMAQ Image to get the length of a line or the distance between two points. This can be helpful for performing distance measurements, defining calibration parameters, or comparing the size of components in an image.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Open the attached file
  2. Run the VI
  3. Select the point tool or the line tool from the Image's ROI toolbox
  4. Draw a line or draw two points (hold SHIFT to draw multiple points)
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Daniel Hays | Test Software Business Manager
Comments
Jony21
Member
Member
on
You help me so much
Not applicable
on
Sorry about my OOO msg... deleting it
