Overview
This tutorial extends upon Daniel's post which is a four wire handshake tutorial
Description
The purpose of the four wire handshake method is to parallelize many tasks. This is very useful when you have tight timing requirements. If your current code has a critical path timing dependency causing the compiler to fault out then you either need to remove, simplify, or parallelize your code to meet your SCTL loop constraints. The four wire handshake is a great method that inherently forces parallelization.
Requirements
Drawbacks and Use Cases
This N Input to M Output design pattern “instantly pauses” when the downstream VI is not ready for data. It could be modified to “pause” only after the next valid output. As such, it should not be used if your function falls into the original 1 Input to 1 Output over N cycles case. You will likely get better throughput as the original design will allow the parallel sets of code to continue to run until they produce a valid output.
Thanks RVines,
This is good stuff - works great - saved me days of work!
This code on custom module with 4 wire handshake design - should be in the Examples collection in the LV installation in some form or another,
There are many examples there on how to use the standard blocks like fifo's and high speed math but none for how to build custom blocks. And 4 wire handshake is really difficult to get right - the back pressure part is the sneaky one.
