Example Code
Drag and Drop Controls and Indicators on Front Panel
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
The example demonstrates how to programmatically move Front Panel elements at run-time with drag and drop mouse gestures.
Description
The VI registers mouse up and down events on the 'movable gauge'. Whenever there is a mouse down event the coordinates of the mouse click location are saved in a shift register. As a next step a mouse up event either on the gauge itself or the front panel pane will trigger the calculation where to move the gauge. With the position property the location of the gauge will be manipulated.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Open the attached file
  2. Run the VI
  3. Click on the Movable Gauge and release the mouse button where you want to move the Gauge to
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Bryan H.
Comments
Todd S.
NI Employee (retired)
on
Thanks for posting.  The image is broken and the file name doesnt include the LabVIEW version.  Please edit this ASAP.
Todd S.
LabVIEW Community Manager
joshuatree
Member
Member
on
can u post as 8.5 or earlier?  pretty please..
Hesloppy
on
I posted a copy in LabVIEW 8.0.
Bryan H.
