Example Code
Continuously Plot Data to XY Graph
Code and Documents
Overview
This VI is a simple example on how to plot data continuously on an XY Graph and make it behave as an XY chart with uncontrollable size.
Description
This VI demonstrates how to use arrays to add data points to an array and then have XY plot update continuously with the values from the array. To use XY Chart with controllable history length, check XY Chart in Example Finder
Requirements
LabVIEW 2012 (or compatible)
Open and run the VI "XY Continuous Plot_LV2012_NI Verified"
Aaron W.
Comments
jtang343
Member
Member
on
Thanks! This helped me a lot!
coolsush
Member
Member
on
Please suggest how to data log the x y graph data points with respect to the time.
try_guy90
Member
Member
on
Use a waveform chart
