Overview
This code demonstrates how to change the color depth of an image loaded from an image file.
Description
This example shows how to use the Picture to Pixmap VI to change the color-depth of your image. This is useful if you want to reduce the size of an image transfered over the network.
Requirements
Software
- LabVIEW Base Development System 2012 (or compatible)
- If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
Hardware
- No hardware is necessary to use this example VI
- Download and open the attached ZIP-file
- Run the VI
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
