Overview
This example VI utilizes property nodes and shift registers to add the points one by one to the graph as the user inputs them with the option to draw a line between the points in the order as they were added as well clearing the graph data
Description
This example VI utilizes property nodes and shift registers to add the points one by one as the user inputs them then they also have the option to draw a line between the points in the order as they were added and lastly they can clear the graph. Property nodes and shift registers are some of the most useful things you can learn in LabVIEW. You can tell by the screenshots how each case works. The add line function is just calling the Plot Interpolation property node that changes it from just points to a direct line.
1. Run the VI "XY Graph Add Point_LV2012_NI Verified"
2. Enter the point coordinates and press on Add
3. Enter another point and click on Add then click on Draw Line
4. Click on Clear Graph to clear all data in the graph
5. Stop execution
Front Panel
Block Diagram
