06-08-2018 02:51 PM
Hello, I have set up 50 virtual channels and all are receiving data from the instruments as I can tell by the changing values when I hit run. I have an OPC client that is showing this channels. Most of the data is send and mimics what is in NI-MAX. But several of the channels are sending a constant steady 0.000000. Does anyone know what could be incorrect? I attached a couple screen shots to show what I mean.
Paul
06-11-2018 06:30 PM
Hi ipauli,
What hardware are you using for these global virtual channels? You see the value changing in NI MAX when you hit run, but on the OPC client you see a constant 0.0000 for some of these channels? Is the problem isolated to specific hardware, or do some channels on a single piece of hardware work while others do not? I am trying to isolate this problem to either the OPC server or the hardware.
06-11-2018 09:30 PM
Hi Adena,
Some strange occurred. When I posted there were about 15 tags that were not reporting. Today there were 6 that did not display. I do not have any idea why the others started transmitting data but I do not care at this point. If they stop relaying data, I will certainly relay the problem.
For the other channels, actually 2 of them, I am embarrassed to say, I had the same input sources as others. I corrected them and all is well.
Why some were not transmitting then started is absolutely strange. If I find a reason I will tell but all is functioning now.
Thank you for replying.
i appreciate it,
Paul
