Dynamic Signal Acquisition
How to connect all 80 Channels of NI 6255 to 19" BNC panels?
As you can see on the datasheet http://www.ni.com/datasheet/pdf/en/ds-22 the usual way to connect a NI PCI-6255 80 analog channel DAQ card is to use 2 SCB-68A connenction boxes.
But for me that would be greatly incomfortable because I am using a 19" Server Rack and there is no acceptable way to place and fix those boxes. Additionally they do not deliver a grounding for each channel so connecting a sensor BNC cable makes that very complicated (you would have to split up every cable and create some common grounding connecting that to the 3 "GND" connectors on the PCB.
I have managed to part-solve my problem by obtaining a BNC-2090 19" rack mount panel (http://sine.ni.com/nips/cds/view/p/lang/en/nid/1177) that pretty much covers all the imputs of the first connector ("NI PCI-6255 Connector 0) with the channels 0 - 15.As far as I have checked, that works well, at least for one part...
It would be great to find something similar that can be connected to the second connector of the NI PCI-6255 and connects all the other channels 16 - 79 directly with BNC on a 19" rack mount panel because I really need all the 80 channels collecting data... Does something like that exist?
(4,164 Views)
You need some switch port to connect 80 NI 6255 because it is necessary to have a couple of spare ports for proper working of bnc panels.
(3,330 Views)
