cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Link labview with MySQL using windows 7
Hello everyone! I've already used MySQL with windows XP, but my new computer has windows seven, and I can't find the way to do it.
I'm attaching the steps I usually follow in administrative tools, but the options I once used are no longer available.
I'm using an access file as a database (DSN=DISTO1)
Can any one send me the steps to do it?
Thanks so much!
Cheers!
0 kudos
Mensaje 1 de 2
3.069 Vistas
Hi WM09,
I am wondering if your Windows 7 is a 64 bits OS??
I have tried to make LabVIEW work with Data Bases and I had no success, I had to install a virtual machine to install Windows XP 32 Bits.
The thing is that when you try to make the connection file, for some reason Windows did not make the connection file right.
Luis Elias
NI VeriStand and HIL Product Manager
0 kudos
Mensaje 2 de 2
3.051 Vistas
