07-18-2014 03:41 AM
Hi there,
I have an NI PCIe-6509 digital IO card. I want to program to set the 96 chanels high/low by using C# programming language and I have no idea where to start. Can someone point me to the right direction? Is there any sample C# code related to NI PCIe-6509?
Ps. i am using windows 7, 64bit operating system and visual studio 2010.
Regards
07-20-2014 08:26 PM
When you are installing DAQmx driver, be sure to select the corresponding .NET framework support.
After you finish the installation, you are able to find the .net examples for PCIe-6509.
07-21-2014 04:57 AM
Thanks for reply.
I installed NI DAQmx 9.7.5 and did select .NET framework support.
I found some ANSIC, VB6, C, and CVI examples but none of it is C Sharp example.
Should I install a leter version of NI DAQmx driver?
07-21-2014 08:50 PM
You might have to uninstall and reinstall the DAQmx driver again.
Here are the snapshot for your example references.
